Modify multiple views at same time ?
Is there a way to turn on or off the display of a part in a draft file in multiple views with one command sequence?
I seem to remember this being a feature that was added to one of the recent versions of SE.
Gary Dinges | Mechanical Design Engineer II | Probes & New Product Development
Emerson Commercial & Residential Solutions | Therm-O-Disc, Inc.| 1320 South Main Street | Mansfield | OH | 44907 | USA
T +1 419 525 8554
gary.dinges@emerson.com
Re: Modify multiple views at same time ?
Select the views that you want to hide the part from and then select the Edit Properties button from the ribbon. You can then switch to the display tab, select the part you want to hide and uncheck the Show box.
Betreff: Modify multiple views at same time ?
Hi @Gary_Dinges
or besides what was mentioned by @BenWeisenberger  You can do a ALT-RMB double click and go to the properties of all selected views.
But finally the result will be the same!
Wolfgang
