Molded Parts
If I was wanting to create a part based off of a already created mold what would be the best method to accomplish this?
Betreff: Molded Parts
Hi @lostriver211
probably it might be the best way to make a part copy (associative in traditional) as construction body and then use a boolean difference to get the molded part out of it.
Wolfgang
Is there a way to only select certain features (ie not wanting screw holes, and/or sprue holes) to subtract besides suppressing them on the part level?
Re: Molded Parts
Honored Contributor
Honored Contributor
Copy the files, delete what you don't want.
