Monitor aspect ratio controls?
Honored Contributor
Honored Contributor
Is any method available to calibrate the aspect ratio of a windows monitor.
In my case the specifics are Nvidia Quadro K4200 and Asus 24" monitors. One uses HDMI and other a DVI.
My goal is to compaire finished model to the real part when holing the part up to the screen when zoomed to the correct size.
