Monthly w/Multi-versions
Hi.
If I purchase monthly I assume I get latest release?
What if I wanted to work on both st8 and say st5 for a particular customer?
Is that possible?
4 REPLIES 4
Re: Monthly w/Multi-versions
Community Manager
Monthly licensing (subscription) would be of the latest Solid Edge release (ST8 today).
Theoretically multi install should work with ST5 and ST8 subscription.
Items to note:
- ST5 would have to be installed before ST8
- ST8 would have to be the active installation to get the new monthly license.
- Multi install was never intended for production use.
Laura
Sounds good Laura! I have a ticket in to engineers to confirm.
Hopefully the the older software packages would be made available via the web.
I think doing monthly and providing upward/downward ability is an awesome advantage to engineers and designers. This alone is nice - now combine that with the incredible power SE offers. Syncronous is tops.
You can manually download an earlier version of Solid Edge by using your WebKey account assigned when you initially purchased your subscription.
Sounds like a plan UK_Dave! Thanks!
