More information on Install that will NOT run
N/A
I've read all the other posts about installation problems, and tried everything
mentioned. I even re-registered to confirm that my SELicense.dat file was valid.
Still not luck. The install appears to work without any errors but when I try and
run I get an HourGlass for a few seconds and then it exits. Edge.exe appears in
the process list during this short time. I've tried all the debugging I can think
of and finally discovered some System errors that get logged when the program fails.
Here they are, hopefully someone can shed some light on why.
Generate Activation Context failed for
C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_dec6
ddd2\MFC80.DLL. Reference error message: The operation completed successfully.
Resolve Partial Assembly failed for Microsoft.VC80.MFCLOC. Reference error
message: The referenced assembly is not installed on your system.
Dependent Assembly Microsoft.VC80.MFCLOC could not be found and Last Error was
Re: More information on Install that will NOT run
N/A
Tony,
Please check the following. In Windows Explorer put your cursor over the SE2DDraft.exe
file that you downloaded. Click the right mouse button while over the file and click
on Properties. Click the Digital Signatures tab in the Properties dialog. Check
the date in the Timestamp column. It should be Tuesday, September26, 2006.
This sounds like a problem we had in the initial executable we posted on Sept 7.
The problem fixed only happened on a limited number of machines so it was not a
wide spresd problem. There was a new executable posted on September 27. Please respond
to this posting and let me know what date you see for the timestamp.
Rick B.
N/A
That's it mine says Tuesday, September 12, 2006, 2:24:27 PM
N/A
Tony,
Uninstall the your current version of Solid Edge 2D Drafting. You can do this with
Add/Remove programs. Go to the registration site and register again to get to the
download. It is OK to register again. Download the SE2DDraft.exe again and reinstall.
Follow the license directions again. Please respond and let me know how it goes.
Rick B.
