Motor Lobes Raise and Lower Rotary Pins
Since this is a smaller version of the bigger picture. I would use the motor lobes to raise the rotary pins. (in and out). Not fur sure how this done.
Thank You
Greg
Betreff: Motor Lobes Raise and Lower Rotary Pins
Hi @PO_LC
if You give a CAM relation to the pins headers, the will move according to the contour
Wolfgang
