Move an entire 3D sketch
Dear all,
I have a 3D sketch for a pipe that is derived from a previous part.
I would like to move it and align it to the main reference plane.
I post a picture that maybe it's more clear...
Any suggestion?
Re: Move an entire 3D sketch
dimension it and constrain it fully (within itself) so that the shape is "rigid". Then constrain it (connect, parallel) to the base coordinate system.
It's difficult, but it works!
Thanks!
