Movement lines - markers
Hi Edgers,
Just wondering if there is a chance to see the movement lines of the assembly parts ?
like on the attached picture ?
thank you,
Arek
4 REPLIES 4
Betreff: Movement lines - markers
Hi @arekkul
I think I remember an old macro for SE doing this.
I will take a view next time in office
Wolfgang
Hi @hawcad,
that's very kind of you,
thank you,
Arek
Hi @arekkul
so after a longer search I get lucky with finding the article and macro
See following link:
http://pathtracerforse.codeplex.com/
and it was coverd here in the forum too:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Trace-curve-in-Solid-Edge-ST6/m-p/2...
Wolfgang
Hi @hawcad,
thank you.
regards,
Arek
