Need 64 bit ST6
N/A
I just started downloading Solid Edge version 6 Student Edition from the download link mailed to me by Siemens PLM Software Inc. But the download file name is showing that its a 32 bit version and I require 64 bit version.
How should I download 64 bit?
Pratheek
Re: Need 64 bit ST6
Esteemed Contributor
You don't require the 64 bit version. The 32 bit version will run just fine on Win 7/8 x64. The student version is only available in the 32 bit version.
Production: ST10 MP5
Testing: SE 2019
Re: Need 64 bit ST6
Hi Pratheek,
You do not need a 64 bit version, this 32 bit version will work perfect on
your 64 bit computer.
You will need a 64 bit version if you are using huge assemblies with 10.000
+ parts..
Since a student will not do this, Siemens decided to make only the 32 bits
version available for students.
Install it and have fun, using this marvelous tools..
Jan Bos
The Netherlands
http://www.linkedin.com/pub/jan-bos/30/aa3/b56
"pratheek.rs@gmail.com"
wrote in message
newsSmiley Tongueratheek.rsgmail.com.64g81b@noreply.bbs.industrysoftware.automation.siemens.com...
> Hello,
> version.
> Thanks,
> Pratheek
> pratheek.rs@gmail.com's Profile:
> https://bbs.industrysoftware.automation.siemens.com/vbulletin/member.php?userid=634664
> View this thread:
> https://bbs.industrysoftware.automation.siemens.com/vbulletin/showthread.php?t=53414
Re: Need 64 bit ST6
N/A
Thank you Grundey, Jan Bos. It's working
