Need help removing a feature in Synchronous
I have an imported mold cayity that I need to modify, There is one small feature that I can not get to go away. I have tried as much as I know to do.
One of our products needed a circuit board change which is requiring the case be modified to accomidate changes. I did original case in Solid Edge, but the mold models were done by mold maker. There are numerous small changes needed and I wanted to include the mold cavities so I could better explain changes. The green features in mold are additions. I have anothe copy of mold that I will highlight removals. Some of the additions/removals overlap so I want to send a before and after, the after version will have removals in red, but that's rather easy to do. To get the after I need to get removed features deleated. The part I can't delete is on a curved surface.
I attached original version & modified one.
It is the red colored rib recess.
I am on ST7 MP11, I have ST8 avaliable, just haven't loaded it.
Gary Dinges | Mechanical Design Engineer II | Probes & New Product Development
Emerson Climate Technologies | Therm-O-Disc, Inc.| 1320 South Main Street | Mansfield | OH | 44907 | USA
T +1 419 525 8554
gary.dinges@emerson.com
3 REPLIES 3
Re: Need help removing a feature in Synchronous
Is this the feature?
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
I hope this technique demonstrated by Allyplm helps you Smiley Happy
https://youtu.be/Er5bDRfNIhg
Yasser
"The key is in the radius"... You have to delete them too... It works well in ordered and Synch mode too.
BR,
Imics
