Need help with dimensions
Whenever I place a dimension I get a VXXXX (the X represents a number) than an equals sign and then the correct dimension. I would like just to have the dimension. I am kinda old and when I looked this up in help I could not find an answer. I know there is a name for the first part but must not know the language. Thanks in advance for your help.
Re: Need help with dimensions
What you have done is to set dimensions to show the variable name instead of the value for the dimensions. Right Mouse Click on a dimension. You will notice that 'Show All Formulas' is currently checked. Click on 'Show All Values' to set the dimension display back to value display.
Rick B.
