Need help with my e-guitar project
What's up guys! It's been a while since im busy with my current project: creating an identical Stratocaster Guitar. And I've got some struggle while I'm on it. Currently I can't quite figure out how to make the highlighted curve shown on a example model on the image belown.
I was hoping you guys could help me. Thanks in advance!
Re: Need help with my e-guitar project
Hi there,
Could you use a sweep, with two profiles to get this back cut?
Below, please excuse my 5 second guitar profile, I show a surface created from the curve & line geometry, as I didn't bother creating further model detail, but the same could be used as a swept cut, through your body design.
