Betreff: Need help with my project
Hi @astrixkid
I've forgotten to mention that the conversion of the two tool bodies into Construction Bodies is not absoluteley necessary.
The Sweep Cut also works if they are Desing Bodies, but then You have them included within the mass calculation of this part, what I suppose is not Your intend.
Wolfgang
Success!
I had been using Sweep instead of solid sweep!
Looks like I should be able to finish it now!
I will post my results later!
Thank you again Wolfgang!
Jim
