Need help with print quality in 3D view, I'm guessing in settings somewhere
Builder
Builder
I can print .dft perfectly clear, but when I print from .asm the image is very fuzzy printed in monochrome, no clarity of parts at all. Color images print clear. My system recently went through an upgrade and this started immediately after, so I believe it must be related to a setting change. I am working with ST6. Any thoughts appreciated. Thanks
Re: Need help with print quality in 3D view, I'm guessing in settings somewhere
Honored Contributor
Honored Contributor
It sounds like the rendering is in control when you ahve high quality, and no rendering (screen resolution) in other situations. As I do not have the rendering package, I cant help.
I'm gettin low quality 3D as well, but I assume it was the lack of rendering option.
