Need to downgrade
N/A
Hi I have st6 installed on my laptop but at shcool we still have st5. I need to do some schoolwork but I can't cause i can't open st6 document on st5. How can i downgrade to st5 ??
Thanks for answering me fast !
Re: Need to downgrade
Unfortunately the files created in ST6 will always be that way....however, you could export them using a neutral format like Parasolid / STEP / DWG , etc.
You can still download the ST5 version for a while longer and I'm pretty sure the newer license file will still work. You cannot run both on the same computer, so you'll also need to do a full uninstall.
Here's the ST5 link:
http://dl2.plm.automation.siemens.com/solidedge/SolidEdgeV105ENGLISH_32Bit.exe
Solid Edge ST10 [MP8] Classic [x2 seats]
