Need to remove broken-out section from a section view?
So I had a regular section view. Still with me? Then I decided to place a broken out section within that section view. Now, if I wanted to modify a broken out section or delete it altogether, I'd have to click on the view and toggle the show annotation or profile button, which would then show the broken-out section border that had been drawn in.  That's if the broken out section was within a normal principal view.
But since I created this on a section view, when I toggle the show profile, it toggles on and off the cutting plane that the primary section was projected from, but I can't get it to toggle on the display of the broken out section, and because of this I am currently unable to either modify the broken out profile, nor can I even select the profile to get rid of that broken out section.
Anybody know how I can  remedy this without deleting the primary section view?
ST9
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
Re: Need to remove broken-out section from a section view?
So you made a view, made a section of the view, then made a broken-out view on that section?
You are unable to edit the broken-out view?
I am unable to replicate this issue on ST7 MP11.
Esteemed Contributor
Hi there @nominus38,
I was able to do all of your steps, successfully.....I'm on ST8-MP5 though.
Maybe an update there that helps it....?
Solid Edge ST10 [MP3] Classic [x2 seats]
Okay, I didn't know about that box. If it had just been on a regular view all I need to do is hit the toggle. Thanks.
ST9
