Negative Bend Angle in Draft Environment
Is there a reason I'm getting a negative angle (-) when placing a dimension with the property text shown?....I know it's down...but we just upgraded from ST4 to ST8 (MP4) and ST4 didn't add the negative sign.
Re: Negative Bend Angle in Draft Environment
Is this for a flat pattern?
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
Yes, on a draft
It could be that Solid Edge is determing the bend directions and is calling them out based on the info in the flat pattern.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
I kinda figured that much, but is there a way to get rid of it?
My prints are using %BN for the angle, and not giving a negative number.
ST8 MP9
Go FAST, or go home.
Thanks @BoatTech! That did it!
