New Baloons
I have a draft with assy andhas baloons already. I added 2 parts and updated views and table. I see my 2 items in updated bom. How do I add new ballons that are related to bom number?
Re: New Baloons
On the Ribbon Bar for the balloon, Select the Link To Parts List and Select - Item Number options and the new balloon will attach to the existing BOM.  It can then be renumbered per your choosing.
Dale Smith
Mitsubishi Electric Power Products, Inc.
ST10 MP7 - Insight
Re: New Baloons
Dale,
I used "balloon" in "annotation" ribbon then "Select the Link To Parts List". Then I selected a part in the assembly. The balloon comes in - but with number that does not match bom and does not have qty value below it. Probably doing something wrong.
Re: New Baloons
Dale,
I did a back door method. I added another table and picked same view and balloons popped in perfect. I then deleted the new table. Works.
Re: New Baloons
Both the "Balloon - Link to Parts List" and "Balloon - Item Number" need selected for it it work.
Dale Smith
ST10 MP7 - Insight
Re: New Baloons
I will have to try again Dale. Thanks.
