New User having Download Problems
N/A
I just downloaded the files but I get an error message when trying to run stating the extractable files were corrupted. Has anyone else encountered this problem? Any solutions?
Re: New User having Download Problems
N/A
This error is seen when the download was not completed or is truly
corrupted.
You can go through the process of downloading again.
There is no problem with registering again.
Check the file size of the executable you downloaded.
It will be around 375MB in size.
Rick B.
N/A
Thanks Rick, I downloaded it and did a "Run" file instead of "Saving" file and everything worked fine the second time. I look forward to using the Solid edge 2D.
