New face style saved incorrectly
Hi all,
I want to create a new face style in assembly environment. I opened the ISO Metric assembly template and created a new style called "Galvanized steel". I set the appearance and the texture, used "surface" and scaled it to X=1 and Y=1. Then I used organizer to saved the new face style into Materials-DIN library.
When I use the new face style in a new assembly, Solid Edge has for some reason changed the scaling values to be "world" and X=0,03 and Y=0,3. Any ideas why is this happening? It happens every time and even after I restarted my computer.
Re: New face style saved incorrectly
Hi @Teemu
I am unable to recreate the problem with ST 8 MP 5.
What is your Solid Edge version and MP ?
~Tushar
I have ST7 and I installed the latest MP 11. After installing, the problem didn't occur anymore. Thanks for help!
