No Download Link?!?
N/A
I only have 24 hours to download the program from a link which didn't appear on the e-mail!!
Help please!!
Re: No Download Link?!?
N/A
Hi there,
As I just mentioned in another post...
"Although I have not tried this myself...why not just go through the whole sign-up/download procedure again from scratch."
...then you'll have another 24 hours to make use of the link.
Sean.C
On 9/6/2011 8:01 AM, reusserg@gmail.com wrote:
I only have 24 hours to download the program from a link which didn't appear on the e-mail!! Help please!!
I suggest trying the download link again
N/A
The original email I recieved failed because of the link didn't work, I've tried registering again with the same details but still waiting for the new email to arrive with hopefully a link that works. Any suggestions on the best way of recieving the .exe file if the link fails again? I have the license file saved locally (will this still work now that 24hrs has expired?)
Any help will be appreciated.
Cowboy-jack,
I've sent you an email to your hotmail account.
N/A
Help please!!
Read this and try the link that i have given...
Siemens ask for student registration before downloading. After registration, they send a link to your email id and also SE License.txt as an attachment to the same email. The link provided into email from Siemens is valid for download in 24 hours only : just check that link carefully... it will contain following link as a part of download link...
if you want to download solidedge st4 directly and in more than 24 hours(especially when using low speed internet), then use this link (paste it in browser address bar) :
http://dl2.plm.automation.siemens.com/solidedge/SolidEdgeV104ENGLISH_32Bit.exe
address in above link (after http://) : dl2.plm.automation.siemens.com/solidedge/SolidEdgeV104ENGLISH_32Bit.exe
and don't forget to get valid student license for above copy of st4, by registering yourself on siemens website... ignore if u have received license
hope you will be able to download st4 now...
N/A
and don't forget to get valid student license for above copy of st4, by registering yourself on siemens website... ignore if u have received license... license file do not have 24 hr restriction....
N/A
GLISH_32Bit.exe
2Bit.exe
restriction....
