No License File or Activation Code for free Solid Edge 2D
I downloaded the free Solid Edge 2D software, but when I run the program I get the message that my copy must be licensed for first-time use and a Solid Edge License Utility box pops up with several license options, and with an SE CID number at the top.
I have not received an e-mail with a License file or an Activation Code – is this what I am missing? Any help will be greatly appreciated.
4 REPLIES 4
Re: No License File or Activation Code for free Solid Edge 2D
If you select the option at the bottom (Viewer Mode/Free 2D), does it launch?
Kevin Grayson
Solid Edge Technical Consultant
kevin.grayson@siemens.com
Hi there @DRC-Enviro,
It is built-in now....just choose the lower most option.
Thank you both, Grayson and SeanCresswell - the "viewer" part of that option threw me off.
Your quick responses are much appreciated.
Dear,
What version you have?
If version is latest Solid Edge 2019, When you print your document  "is there a water mark of "SOLID EDGE 2D DRAFTING?".
Irfan Pathan
