No line command in sheet metal, ordered
Not applicable
Finally got through the first sheet metal tutorial, it gets better as it goes but the beginning is pure pain. If you don't find the tool that the tutorial says to use such as the line command, switch between Synchronous and Ordered, you will find these under the "Tools" tab, look on the left in the "Model" group. After switching between these, go to the "Home" tab and you will see different tools.
Solid Edge folks, your first sheet metal tutorial needs some work, you don't explain switching between Synchronous and Ordered to find these tools, such as the line command and tab, took me two nights to get through the first sheet metal tutorial. Very frustrating to have to switch between these.
