No ordered mode available in ST
I just put the student version of SE on a brand new laptop and at the start of a new part I only get the taskbar according to the picture below.
In the options I have selected to start standard in ordered.
Why can i not draw with ordered features?
Betreff: No ordered mode available in ST
Esteemed Contributor
Hi @KurtCouffez
according to Your image You are already in Ordered mode.
So there is no further need to change to it as You already are there.
Wolfgang
You are in the "Next Steps" theme which is designed for working with Synchronous only.  You will not be provided with any Ordered commands in "Next Steps".
Change your theme to "Solid Edge - Balanced Default".
To change themes right-click on any of the tab headers, select Themes -> Solid Edge - Balanced Default" (or any other theme that provides an Ordered UI interface)
Hi @uk_dave
so I'm working with and for Solid Edge that long time, but never ever realized that there is a theme called "Next Steps" nor the "First Steps" theme.
Great is every day where You can learn some new!
Wolfgang
This has solved my problem.
What the goal is of these themes is a mystery to me.
The "Next Steps" theme is available to Student versions and its goal is to keep it simple for new students.  The other themes are really a way to taylor the workspace to your preference and provide additional assistance to new users with all commands available.  You can also create your own themes if desired.
Production: ST10 MP5
Testing: SE 2019
