Not able to access standard parts from server
  I have completed Standard parts installation in server & i tried to access it from client machine it is not opening and giving error message as "SQL Network Interfaces error: 26- Error Locating server /Instance specified"
[attaching screenshot]
please help me to solve the issue at the earliest.
Thanks & regards
Mahesh
Re: Not able to access standard parts from server
Did you set your "Standard Parts SAC file" file location setting (Solid Edge Options, File Locations) on your client PC to point to the SAC file generated by the Server?
Production: ST10 MP6
Testing: SE 2019
Hi Mr. Ken,
  Thank you for your reply, yes .SAC file link was given in client machine on server location.
Thanks & regards
Mahesh
Just go anywhere on your system and create an empty text file named anything but instead of txt make sure the extension is UDL.  Then, double-click on the file and up pops a SQL connectivity window to allow testing of remote SQL connections.
Then type in your server and the usercredentials you have given in the Configuration of the Setup.
Check also my uploaded picture.
