Not warning me to save
Hi
If I open a file do some work on it and close it it's just closing without saving its not remembering me to safe and it's not warning me if i override a file while saving if i do so.
How can i get that back?
Re: Not warning me to save
I don't know of any setting available to turn that off so it would appear a corrupt user profile or busted install.
For clearing the user profile, you have to edit your HKEY_CURRENT_USER registry section and with Solid Edge closed, delete the following key:  HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge.  This will reset Solid Edge to a fresh install state with no user settings.
BE CAREFUL!  Editing the registry and deleting/changing the wrong thing can cause your PC to no longer start up or application to no longer work.  Only do this if you are comfortable doing so.
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
