O Boy.... Callout Properties. can not right click to copy note
In callout properties you can no longer right click on a hightlight text to copy or right click at all to paste something. what's up with that??????? This something we use a lot!!!!!!
Re: O Boy.... Callout Properties. can not right click to copy note
Hi there,
I'm not having this issue, and am able to copy/paste to, from & within other call out fields.
interesting. it's all the computers not just mine. 5 computers so far. i'll do a vid tomorrow
@TDB, Same here. No problems with it.
Bruce Shand
I'll try this first. this is where it doesn't work. Like i said before, it's like this on all 5 machines not just one machine
Works correctly for me also using MP1.
Curious, what's the reasoning for the lower text box?
lower text box got added i think in ST7. i never use it
No, it has been there a while.
Bruce Shand
stand corrected. still love to know why it's there?
Called in my problem. It's a know problem and should be fixed in mp2 or 3. work around is CTRL-C then CTRL-V
I beleive that it's only purpose is in a case where you do not embed the text in the leader but instead show the text on top of the leader line, then the secondary text shows below the line.
http://Grundey.blogspot.com
