Occurrence properties multi change
Builder
Builder
When changing occurrence properties in an assembly it is possible to multi select a number of parts but not possible to then change all the selected parts to 'yes' or 'no' in draft reference
It would be highly beneficial if multiple parts properties could be changed together instead of having to change individually or is there a way to do this ?
Re: Occurrence properties multi change
CTRL-C (Copy) an "NO" and select which you want to change and then CTRL-V (Paste). Occurrence properties is one of the few environments where you are allowed to use ctrl-c/v/x.
Sander
The Netherlands
Builder
Builder
Thank you for the tip, I tired this using CTRL-C and CTRL-V but didn't work however using RHMB copy and paste did work, big time saver, thanks Smiley Happy
