On line help
Honored Contributor
Honored Contributor
When I can get on line help to open, I can't search it with more than a single word. If I type in two words, I get no results.
Any work arounds or sugestions welcome.
Re: On line help
Esteemed Contributor
Are you running IE 11 by chance?  I have reported this.  The workaround I do is past the help URL in to Chrome and search there.  Works fine.
Production: ST9 MP10
Testing: ST10 MP3
Re: On line help
Honored Contributor
Honored Contributor
Nice. I can actually search full help!
This should keep me from asking so many small questions here.
Re: On line help
You can also switch from "online" help to "local" by unchecking the "Use my web browser to display help" found under Solid Edge Options-Helpers.
Kevin Grayson
Solid Edge Technical Consultant
kevin.grayson@siemens.com
Re: On line help
Why does IE come up when Firefox is my default browser?
Using SE since V12, 2002
Re: On line help
Because SE is hard coded to use IE for On Line Help.
Testing: ST10 MP3
