Open NX part
we have two product line located on different site.
One product line use NX and the other Solid Edge.
We are on the same company and standard parts are the same, for example screw M8x50.
We aren't under Teamcenter, but our PDM generate JT file for each 3D parts.
Can a Solid Edge user open a NX .prt part or JT part without convert them on save ?
Thank you...
Using NX 11 / RuleDesigner PDM
Re: Open NX part
This will help you:
SE and NX
BR,
Imics
Re: Open NX part
I'd like to start a seperate discussion with you about RuleDesigner. I'm currently using DriveWorks Professional along with DriveWorks Live and looking at othe solutions that might help in a multi-CAD environment- things like RuleStream and Cincom.
