Open ST4 par File with SE V19?!
N/A
Hi guys,
do you know any way to open ST4 files with the ST V19?
Greetings Georg
Re: Open ST4 par File with SE V19?!
N/A
On 12/07/2012 13:40, georg.lindner@hs-bochum.de wrote:
> Hi guys,
> do you know any way to open ST4 files with the ST V19?>
> Greetings Georg
1) Files are not backwards compatible (in common with most software)
2) SolidEdge V19 was not ST
3) If you MUST open ST4 files in previous versions, try export as
parasolid and re-import. I don't think this will work with files from
the "free" student edition. One of the trade-offs for getting it for
free was a restriction on re-use.
Alan
