Open Type font in Solid Edge
I need to insert an openType Font text, is it correct I can't do this?
Solid Edge ST10 & AutoCAD 2018.1 user
Re: Open Type font in Solid Edge
Per GTAC Solution Center article 002-7004573, OpenType fonts are currently not supported in Solid Edge.
Usually online it's easy to find the same font in TTF format.
Or you could try a OTF to TTF conversion tool.
This is the first I found with google search: https://everythingfonts.com/otf-to-ttf
@Fiorini Thanks! Didn't knew this was possible.
What I did:
Type the text in Illustrator
export as dwg
open in draft
copy sketch
paste in part.
Man Tongue
Esteemed Contributor
Joris wrote:
What I did:
export as dwg
open in draft
copy sketch
paste in part.
Ahh yes, those hurdles we have to jump, in order to get "exploded" text to use as geometry.
In fact, THIS belongs in the "How to spot a real Solid Edge user" topic! [already in the pet peeves]  Robot Frustrated
That was one of my biggest bullet points to address with the Solid Edge team at the recent Boston usergroup meeting! I hope something is done in a coming verison...
-Dylan Gondyke
In ST10, still not possible... Man Mad
