Open file wrl format
Solid Edge can open WRL format?
Re: Open file wrl format
No, Solid Edge can export vrml ('save as image/*.wrl') but not import.
There exists an Enhancement Request for this, so please add to this ER via your support organisation.
Regards /Ulf
Siemens EMEA GTAC Support
Thanks for your answer.
You can transfer the WRL to STL with meshlab (http://meshlab.sourceforge.net/) but you will just get a viewable representation of the 3D.
You can not edit the model nor creating a 2D-Drawing or even measure it.
The only way to have a real 3D-Model in SE to o convert this to a solid.
See this discussion
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/STL-File-to-Solid-Model/m-p/343191#...
Stefan
smitsch@unitec.de
www.all4edge.de
