OpenSave Macro
Has anyone else had any problems getting the OpenSave macro to run in ST10? I tried to run it today on a small folder with some sub-folders and it crashes out after about 30-45 seconds just as it begins to process files. I had it set to run all files: Part, Assembly, & Draft. All files that I tried to run are local.
I was just wanting to update all of the files in the folder to ST10. Not a big deal but thought it might allow files to opena bit quicker as every time I opena an old file it notes at the bottom of the screen that it is updating to current version. Our files go back across many old versions over several years.
TIA,
Bob Henry
REH Technical Consulting
Canonsburg, PA 15317
Betreff: OpenSave Macro
Hi @rehenryjr .
I will do a test later
Wolfgang
This is a known issue on MP4 and MP5 which should be already fixed in MP6.
Hi @uk_dave
thanks for that info.
Wolfgang
@uk_dave Thanks for the information. As noted in another post, it seems like someone has been asleep at the wheel with these latest ST10 MP's. I can't recall anything like this in a very long time.
This one is certainly not a show stopper.
Tahnks again.
Bob Henry
