Opening .DFT file in Solid Edge ST8 in multiple instances on Windows 10
i have problem, when i open *.dft file in SOLIDEDGE ST8, it is still opening in new instance, so i have multiple instances opened. How can i turn it to have it all in single instance? For anothers users it working fine - but they are on Windows 7, I have Windows 10 and only there is problem. Many thanks
Re: Opening .DFT file in Solid Edge ST8 in multiple instances on Windows 10
Hi @PACS
Here's a similar discussion about DXF files and I believe you may need tweak the registry file to adapt this for DFT
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/How-stop-new-windows-opening-when-d...
or hope @uk_dave gives you a customized solution.
