Opening STEP files in ST7, is not working
When opning a STEP file in ST7 and files from ST2 the piece become over sized 1000 mm.
Does anybody know or have a solution for this...? as ST6 doesn't had this problem
Kind Regards
Fernando Cruz
Re: Opening STEP files in ST7, is not working
Esteemed Contributor
I work with vendor provided step files quite a bit using ST7 and haven't experienced a problem.
A possible solution would be to insert a copy of the scaled down part into a new part and apply a corrective scale as you do so.
Bruce Shand
Unfortunatelly that's what i have being doing, but this problem appears with ST7, as i have being receiving files from this customer for a many years, and with all earlier versions of Solid Edge i never had any problem.
  And what is strange is the STEP files have been done ina earlier version of Solid Edge (ST2)
Thanks for you comments
Fernando Cruz
If you can attach an original step file I'd be glad to try it.
If they were originally ST2 can you get those versions instead of step?
Have you discussed this problem with your reseller or with GTAC?
Bruce Shand
There's the file, but with this one I have some more, this one is the
smaller one
Kind Regards
Fernando Cruz
Este e-mail foi verificado em termos de vírus pelo software antivírus Avast.
http://www.avast.com
Whenever possible...  ALWAYS  try to get native files.
if you can not get native go for parasolid...
othewise step...
and if you had too... "i guess" send me an iges...
this way we translate data 1 time  not 2x..  once out and once back in...
dont forget Solid Edge can open most of the main players native file types...
and...  parasolid is the kernel sharded under the hood between SE, SW and others  so the native data is "the same" and there is really not tranalation of the data
Yes, i did report it for a long time and nothing has been done until today
Best Regards
Fernando Cruz
Did you attempt to attach a file? If so, no luck. Maybe change the extension if you're getting blocked to .pts or something.
What Matt said is true. ST2 would be best. Parasolid is not always available but if you are requesting files from your supplier he could supply it in that format presumably.
Bruce Shand
Yes, i did attached the file, i don't know where it is here on the forum
Best Regards
Fernando
It should appear right below your post.
Bruce Shand
