Opening Solid Edge Viewer Fails
N/A
I would like to open Solid Edge Viewer and a failed document box shows, How can I fix this.
Crousie
Re: Opening Solid Edge Viewer Fails
Crousie,
I just saw that Solid Edge Viewer is NOT working under an account without administrator privileges. This is a problem, which was solved under ST5 MP2.
So you probably make sure, that you have administrator rights.
