Opening an assembly on other computer
Hello all,
I have a problem, namely that I made an assembly in a specific folder, and most of the parts are saved in other folders. Now when I tried to open my assembly on an other PC, I got an error message, saying its either wrong file format or I don't have access to the file. But I'm guessing its rather that the program can't retrieve the parts of the assembly, because it is looking for them through the originally given path, which isn't working, because the the whole containing folder has been moved to another location/drive etc.
I hope someone can figure out how I could open and keep on using my files, since I worked for ages with them.
