Opening an assembly/transfering parts
Im using ST9 and finding that Solid Edge times out quite alot in the following examples:
I have a large assembly and I want to open an assembly within this file. I right click the file and press open and it starts doing its thing to open the file and then will just stop.
Transfering parts - select parts to transfer to another file; it starts off as if its tranferring and then just stops.
Does anyone else see this or is it PC specific?
Graham
3 REPLIES 3
Re: Opening an assembly/transfering parts
Hi @redcad
never faced this issue before - all is working fine, transfering and opening subassemblies.
Maybe there is an issue with the network ?
Arek
Not on a network. Just one PC. Thanks though G
Sometimes it work - try to re-install the last Service Pack ....
