Opening multiple .DXF's
Occasionally after drawing my sheetmaetal parts and flattening I'll open the .DXf files (they're lasered parts) to double check them as correct before sending to the job shop for cutting. In the past I've been able to select 2-50 .DXf's and open them all at once simply by selecting the .dft as the template, Now I have to select the template for each file. I'm not sure when this changed but it's easily been a year I'm guessing.
Is there an "auto" open all using the same template I'm forgetting about?
ST9 latest MP installed.
Craig
-Craig
Re: Opening multiple .DXF's
@Craig_H,  does this older post help you at all?  https://community.plm.automation.siemens.com/t5/forums/v3_1/forumtopicpage/board-id/solid-edge-forum...
if not,  maybe @uk_dave might have some additioanl insight...
Matt Johnson
Teamcenter 10.1.7
