Opening templates
Not applicable
I downloaded the new ST6, but unfortunately every time Click ANSI Part to develop a new part only the tool bar show up. There is gray screen, and I can still see the default page consisting up ANSI Part, ANSI Sheet Metal, ANSI Assembly, etc. This problem occurred last time when I downloaded ST5, the solution was easy and short, but unfortunately I forgot how to fix it. I took a screenshot to help demonstrate my problem. What do I need to do? I really appreciate your help.
Re: Opening templates
Not applicable
no screen shot attached.
Have you tried other templates? same behavior or different?
Have you searched the forum for the solution to your issue last time you posted?
