Override diameter prefix in dimension?
How do I toggle the variable in the dimension callout shown?
In other words toggle "Radial_Diameter=" on or off
Walter ST10 Win 7 Ultimate
Quadro k4200
Re: Override diameter prefix in dimension?
Right click on the dimension text and select 'Show All Values' in the context menu.
Note however that this will affect not just this, but all dimensions.
~Tushar
www.SurfAndCode.IN
