P&ID Question
Thank you Pellaken for your reply this will holp me get in the right direction on
using this program. Do these block library file you can get do they have to be a
PDF file or something else so they be read by 2D drawing. Also can these blocks
that I make for vessel and valves etc. can they be numbered. In my plant everything
has a number and they expect you to know them all.
