PDF Converter to Solid Edge
PLM World Member Builder PLM World Member Builder
What does Solid Edge use to convert Adobe PDF Reader back to Solid Edge format. And yes I did find the files
Thank You
Solid Edge does not convert PDF files to SE.  You will ha...
Solid Edge does not convert PDF files to SE.  You will have to find a product that converts them to DXF and then convert the DXF into SE.
http://Grundey.blogspot.com
