PDF creation
Hi all,
I am a new user to Solide EDGE.
Need help in resolving the watermark problem saying "SOLID EDGE RESELLER COPY" during PDF conversion from draft file.
I ensured that, this is not a problem of PDF creater software. It seems there is a setting in solidedge needs to be modified to enusre no watermarks while creating PDF from draft file.
Please see the watermark in lower left corner from the attachment
Can any of you help me.
Mahi
Re: PDF creation
You are receiving this because for whatever reason your license is considered a Reseller license.
In order to remove this you must run Solid Edge with a valid non-reseller license, typically a purchased license.
Re: PDF creation
Thank you very much
I will check it
