PDFs created from draft files are not showing shaded views
I am trying to create PDFs of assembly drawings that have shaded views.  I'm using Adobe XI Standard.  When I print the views using the PDF driver, the preview shows the shaded views, but the end result just has non-shaded views.  Any ideas or settings I could try?
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
16 REPLIES 16
Re: PDFs created from draft files are not showing shaded views
How about with save as translated?
I just used save as translated and the pdf995 printer driver and both open shaded in Adobe.
Hi Bruce,
I'll try the save as translated.  I didn't have much luck with it in the past.  All my drawings are multi sheet on B size paper.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
I just tried the "save as" translated and it only handles one sheet at a time.  When I print using Adobe, it will do all of the sheets.  This adds up when I have 10-12 sheet drawings.
The "save as" option does do shaded views.  It sounds like there is something going on between Solid Edge and Adobe.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
I just hope it's not one of those cryptic registry entries required to fix it.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
I don't have an Adobe printer driver to try but pdf995 one is free. You could try that.
Never mind. Multi-sheet didn't work.
Just tried PrimoPDF and it worked. It's a freebee driver I think.
Hi Bruce,
Well, it turned out it was the cryptic registry entry that made everything work.  I had to refer back to Sean Creswell's post back in February of 2014 to get.  I went into DBUG in the ST108 registry and created a new DWORD key with STRETCHMASKBLT with 0.  I tried using 1 and it took forever to make the PDF.
I'm still baffled as to why this has to be done.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
