PMI Section Views
Hi Guys.
I have created PMI section views in a couple of parts and are now in an assembly.
Is it possible to turn these section views in the assembly and on my draft?
Betreff: PMI Section Views
Hi @Dazzie
Yes and No!
Yes, You can use section views in a part to show them in their drafts
and
No, You can not use those sections from a part to be turned on in the assembly
Wolfgang
