PROBLEMS WITH DISPLAYING
N/A
I ONLY SEE THE WHITE SCREEN. BUT WHAT I DREW I CAN PRINT.
LOOK I ALSO FOUND THE CHECKBOX TABLE WHiCH IS EMPTY AND I CAN'T CHECK ANY BOX. MAYBE THAT'S THE PROBLEM?
Re: PROBLEMS WITH DISPLAYING
Esteemed Contributor
Looks to me, that you are running Windows XP.....which Solid Edge is no longer supported on this operating system.
If indeed this is the case, then you will need to upgrade, or install it on a computer, running Windows 7 . This should account for your graphics problems, but it may be more than this...what are your system specs?
Solid Edge ST10 [MP6] Classic [x2 seats]
N/A
Hi. thank You. Iwas running on vista home. but now when i moved to vista bussines everything is fine.
