Package assembly file for distribution
Builder
Builder
Looking for suggestions for packaging up of assembly for external distribution. Have done using revision manager 'copy' but interested to know if there are any useful in-built SE features that will do the same or if revision manager is indeed the best menthod.
Solid Edge ST8 Classic.
A Goodwin ~ Snr Design Engineer
Re: Package assembly file for distribution
Thank Tushar there is the possibility to use:
"Free Pack and Go for Solid Edge"
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/PacEdge-Free-Pack-and-Go-for-Solid-...
Yasser
Siemens Legend Siemens Legend
Siemens Legend
And there might be something additional in ST9 for this.
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/A-Sneak-Peek-into-Solid-Edge-ST9/td...
/Ulf
Siemens EMEA GTAC Support
Honored Contributor
Honored Contributor
If I send a file out, then I also have to send the gage table for the sheet metal. Something left out when just using revision manager.
