Paper Printer Recommendations
A customer is asking for a recommendation for a paper printer for 8.5x11 and 11x17 paper.
Any recommendations?
LMGi
www.TLMGi.com
Re: Paper Printer Recommendations
What class of printer are they looking for?
  • Just a printer (assuming black/white and color)?
  • A Multi-function printer (Print/Scan/Fax/Copy)?
  • A laser printer or inkjet?
  • High volume or low volume printing?
If they can't justify the cost of a laser printer but still need the high volume print capability in an inkjet, the new HP PageWide printers look promising.
http://Grundey.blogspot.com
PLM World Member Pioneer PLM World Member Pioneer
We use an HP Laserjet 5550dN - purchased a number of years ago - makes fine prints. However, this is the last HP printer we will ever buy. If one color runs out, you have to replace all the colors or it complains mightly. Costs about $600 to replace all the colors. Whatever you decide to buy, check the ink replacement costs and factor that in.
For my home office use, I have an Epson WF-7520.
This specific model is obsolete, but they still make the same family of printers.  For a multi-function inkjet printer in a small office environment, it works really well.
____________________________________
--Scott Wertel, P.E.
Honored Contributor
Honored Contributor
We use a very old school HP laser. HP_5100TN
Black and white only
If you need color, get a laser with independent ink for each color.
We had a HP 5100 in the engineering department for 7 years, never had a problem with it. We got "upgraded" to a 5550 color printer, **bleep** thing has to be rebooted at least once a week or it will just hang on prints forever.
Perfect,
I will refer my customer to this thread.
LMGi
www.TLMGi.com
We have an HP 5200 that is workhorse.  Very reliable and toner cartridges last a very long time.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
Ditto on the 5200.
Bruce Shand
